Subsonic sending to moscow.gateway.2wire.net
Postby Coolmax » Sun Mar 15, 2009 11:32 pm
Can someone tell me why Subsonic is accessing this site - moscow.gateway.2wire.net - behind the scenes?
Process: subsonic-agent.exe
Hostname: moscow.gateway.2wire.net
Local port: 3643
Remote port: 1028
Protocol: TCP
Status: Established
Aware since: 3/15/2009 10:42:51 PM
Age: 11:35:05
Recognized as: ???
Process: subsonic-service.exe
Local port: 1028
Remote port: 3643
Protocol: TCP
Status: Established
Age: 11:36:25
Recognized as: ???
Coolmax
Coolmax
Postby sindre_mehus » Mon Mar 16, 2009 10:03 am
If you look at the port numbers you see that subsonic-agent is connected to subsonic-service, as it should be.
moscow.gateway.2wire.net is probably your assigned hostname or something, I don't know. Maybe you have a 2wire router?
Postby Coolmax » Tue Mar 17, 2009 12:49 pm
I have no idea, all i know is im no where near moscow :)
I've just edited my hosts file to redirect moscow.gateway.2wire.net to my local server.
BTW, great program.. Ive tried them all and yours is the best i've come across.. Well done..
sindre_mehus wrote:If you look at the port numbers you see that subsonic-agent is connected to subsonic-service, as it should be.
Coolmax
Postby jigsaw » Tue Mar 17, 2009 4:56 pm
Coolmax wrote:I have no idea, all i know is im no where near moscow :)
Do you have a server or pc with the hostname "moscow" perhaps? :)
That in combination with a 2wire router would automatically generate a reverse dns for the server moscow to be moscow.gateway.2wire.net.
The address for the 2wire itself is always http://gateway.2wire.net
Found this in the installation guide
Seems it has caused some vulnerabilities as well in the past. See http://tech.slashdot.org/article.pl?sid ... 4&from=rss
jigsaw
