Blank page after install
Postby Bray90820 » Mon May 09, 2016 11:55 pm
So I installed openjdk-8-jdk on ubuntu 16.04 and then installed subsonicwith the command "sudo dpkg -i subsonic-6.0.deb'" but "localhost:4040/login.view" just gives me a black page
Bray90820
Re: Blank page after install
Postby stingrey » Sun May 22, 2016 4:53 pm
got the same problem. Subsonic doesn't work with openjdk-8-jre or openjdk-9-jre. You have to use openjdk-7-jre!
sudo add-apt-repository ppa:openjdk-r/ppa
sudo apt-get update
sudo apt-get install openjdk-7-jre
If add-apt-repository doesn't work you have to install it first
sudo apt-get install software-properties-common
stingrey
