Database Backup and Restore
Postby Cantenna99 » Wed May 18, 2016 12:39 pm
Greetings!
Latest Subsonic running on ubuntu server (w jre-default), running as non-root, max mem 200m, only one user; admin sharing 4 folders and under user settings I have enabled admin access to all shared network directories.
Quite often I am finding one of the four shared directories will just appear to be blank!? the only way to fix it, I have to run another scan which takes a good while...
I thought as a shortcut, I could just back up the /var/subsonic directory after a successful scan and restore whenever this happend, yet despite doing this, the directy still remains empty after a restore..But If I do a scan, directory comes back.
Does anybody know of a solution to this frustrating problem I am having? Is there a database outside of the subsonic directory I should be backing up for this purpose? :?
Cantenna99
Re: Database Backup and Restore
Postby alphawave7 » Wed May 18, 2016 2:09 pm
Odd problem. Is this directory on the same hard drive, or another that may have a sleep mode,etc.? Is this the same directory over and over?
Postby Cantenna99 » Wed May 18, 2016 11:23 pm
same directory, server is headless ubuntu with fstab cifs entries to router where the drive is actually located. Read and write permission enabled on Music directory
What I don't understand, why cant I back up a database and restore it? Is it located outside of the subsonic directory? The project could really use a snapshot feature for issues like this.
Cantenna99
Postby Cantenna99 » Wed May 18, 2016 11:40 pm
Hmm, It seems to have worked if I remove the subsonic directory, reboot, check that trying to login throws a jetty error, then restore and reboot again.
Cantenna99
