Temp upload dir
Temp upload dir
Postby josquin » Mon Jun 06, 2016 2:27 pm
First of all thanks for the good job, subsonic really is an amazing project.
Second, due to freespace concern I had to change the dir where subsonic store temporary uploaded files.
To do so, i did pass a "java.io.tmpdir" parameter to java when lauching subsonic.
That said, I've tried to make it clean. You'll find my humble contribition proposal to subsonic.sh attached.
I did add a "SUBSONIC_TMPDIR_PATH"
SUBSONIC_TMPDIR_PATH=/tmp
that can be fead via "--tmpdir-path" argument
document it
echo " --tmpdir-path=PATH The directory where files are temporarily stored during upload. Default '/tmp'"
then do the job
--tmpdir-path=?*)
SUBSONIC_TMPDIR_PATH=${1#--tmpdir-path=}
and finally insert it in the command line
-Djava.io.tmpdir=${SUBSONIC_TMPDIR_PATH} \
That way it's possible to pass the argument through the /etc/default/subsonic file (debian).
Hope that somehow, this could be useful.
Greetings
Josquin
#!/bin/sh
# Shell script for starting Subsonic.  See http://subsonic.org.
# Author: Sindre Mehus
SUBSONIC_HOME=/var/subsonic
SUBSONIC_HOST=0.0.0.0
SUBSONIC_PORT=4040
SUBSONIC_HTTPS_PORT=0
SUBSONIC_CONTEXT_PATH=/
SUBSONIC_MAX_MEMORY=150
SUBSONIC_PIDFILE=
SUBSONIC_DEFAULT_MUSIC_FOLDER=/var/music
SUBSONIC_DEFAULT_PODCAST_FOLDER=/var/music/Podcast
SUBSONIC_DEFAULT_PLAYLIST_FOLDER=/var/playlists
quiet=0
usage() {
    echo "Usage: subsonic.sh [options]"
    echo "  --help               This small usage guide."
    echo "  --home=DIR           The directory where Subsonic will create files."
    echo "                       Make sure it is writable. Default: /var/subsonic"
    echo "  --host=HOST          The host name or IP address on which to bind Subsonic."
    echo "                       Only relevant if you have multiple network interfaces and want"
    echo "                       to make Subsonic available on only one of them. The default value"
    echo "                       will bind Subsonic to all available network interfaces. Default: 0.0.0.0"
    echo "  --port=PORT          The port on which Subsonic will listen for"
    echo "                       incoming HTTP traffic. Default: 4040"
    echo "  --https-port=PORT    The port on which Subsonic will listen for"
    echo "                       incoming HTTPS traffic. Default: 0 (disabled)"
    echo "  --context-path=PATH  The context path, i.e., the last part of the Subsonic"
    echo "                       URL. Typically '/' or '/subsonic'. Default '/'"
    echo "  --max-memory=MB      The memory limit (max Java heap size) in megabytes."
    echo "                       Default: 100"
    echo "  --pidfile=PIDFILE    Write PID to this file. Default not created."
    echo "  --quiet              Don't print anything to standard out. Default false."
    echo "  --default-music-folder=DIR    Configure Subsonic to use this folder for music.  This option "
    echo "                                only has effect the first time Subsonic is started. Default '/var/music'"
    echo "  --default-podcast-folder=DIR  Configure Subsonic to use this folder for Podcasts.  This option "
    echo "                                only has effect the first time Subsonic is started. Default '/var/music/Podcast'"
    echo "  --default-playlist-folder=DIR Configure Subsonic to use this folder for playlists.  This option "
    echo "                                only has effect the first time Subsonic is started. Default '/var/playlists'"
    exit 1
# Parse arguments.
while [ $# -ge 1 ]; do
    case $1 in
        --help)
            usage
        --home=?*)
            SUBSONIC_HOME=${1#--home=}
        --host=?*)
            SUBSONIC_HOST=${1#--host=}
        --port=?*)
            SUBSONIC_PORT=${1#--port=}
        --https-port=?*)
            SUBSONIC_HTTPS_PORT=${1#--https-port=}
        --context-path=?*)
            SUBSONIC_CONTEXT_PATH=${1#--context-path=}
   --tmpdir-path=?*)
        --max-memory=?*)
            SUBSONIC_MAX_MEMORY=${1#--max-memory=}
        --pidfile=?*)
            SUBSONIC_PIDFILE=${1#--pidfile=}
        --quiet)
            quiet=1
        --default-music-folder=?*)
            SUBSONIC_DEFAULT_MUSIC_FOLDER=${1#--default-music-folder=}
        --default-podcast-folder=?*)
            SUBSONIC_DEFAULT_PODCAST_FOLDER=${1#--default-podcast-folder=}
        --default-playlist-folder=?*)
            SUBSONIC_DEFAULT_PLAYLIST_FOLDER=${1#--default-playlist-folder=}
            usage
    esac
    shift
done
# Use JAVA_HOME if set, otherwise assume java is in the path.
JAVA=java
if [ -e "${JAVA_HOME}" ]
    then
    JAVA=${JAVA_HOME}/bin/java
fi
# Create Subsonic home directory.
mkdir -p ${SUBSONIC_HOME}
LOG=${SUBSONIC_HOME}/subsonic_sh.log
rm -f ${LOG}
cd $(dirname $0)
if [ -L $0 ] && ([ -e /bin/readlink ] || [ -e /usr/bin/readlink ]); then
    cd $(dirname $(readlink $0))
fi
${JAVA} -Xmx${SUBSONIC_MAX_MEMORY}m \
  -Dsubsonic.home=${SUBSONIC_HOME} \
  -Dsubsonic.host=${SUBSONIC_HOST} \
  -Dsubsonic.port=${SUBSONIC_PORT} \
  -Dsubsonic.httpsPort=${SUBSONIC_HTTPS_PORT} \
  -Dsubsonic.contextPath=${SUBSONIC_CONTEXT_PATH} \
  -Dsubsonic.defaultMusicFolder=${SUBSONIC_DEFAULT_MUSIC_FOLDER} \
  -Dsubsonic.defaultPodcastFolder=${SUBSONIC_DEFAULT_PODCAST_FOLDER} \
  -Dsubsonic.defaultPlaylistFolder=${SUBSONIC_DEFAULT_PLAYLIST_FOLDER} \
  -Djava.awt.headless=true \
  -verbose:gc \
  -jar subsonic-booter-jar-with-dependencies.jar > ${LOG} 2>&1 &
# Write pid to pidfile if it is defined.
if [ $SUBSONIC_PIDFILE ]; then
    echo $! > ${SUBSONIC_PIDFILE}
fi
if [ $quiet = 0 ]; then
    echo Started Subsonic [PID $!, ${LOG}]
fi
josquin
Re: Temp upload dir
Postby josquin » Tue Jun 07, 2016 1:29 pm
Here is the .bat version
@echo off
REM  The directory where Subsonic will create files. Make sure it is writable.
set SUBSONIC_HOME=c:\subsonic
REM  The host name or IP address on which to bind Subsonic. Only relevant if you have
REM  multiple network interfaces and want to make Subsonic available on only one of them.
REM  The default value 0.0.0.0 will bind Subsonic to all available network interfaces.
set SUBSONIC_HOST=0.0.0.0
REM  The port on which Subsonic will listen for incoming HTTP traffic.
set SUBSONIC_PORT=4040
REM  The port on which Subsonic will listen for incoming HTTPS traffic (0 to disable).
set SUBSONIC_HTTPS_PORT=0
REM  The context path (i.e., the last part of the Subsonic URL).  Typically "/" or "/subsonic".
set SUBSONIC_CONTEXT_PATH=/
REM The directory where files are temporarily stored during upload. Default 'c:\Windows\Temp'"
set SUBSONIC_TMPDIR_PATH=c:\Windows\Temp
REM  The memory limit (max Java heap size) in megabytes.
set MAX_MEMORY=150
java -Xmx%MAX_MEMORY%m -Dsubsonic.home=%SUBSONIC_HOME% -Dsubsonic.host=%SUBSONIC_HOST% -Dsubsonic.port=%SUBSONIC_PORT%  -Dsubsonic.httpsPort=%SUBSONIC_HTTPS_PORT% -Dsubsonic.contextPath=%SUBSONIC_CONTEXT_PATH% -Djava.io.tmpdir=%SUBSONIC_TMPDIR_PATH% -jar subsonic-booter-jar-with-dependencies.jar
It may be necessary to add a field to the subsonic agent to modify subsonic-service.exe.vmoptions I guess.
Have a good day.
Josquin
josquin
