HTTP Error 404 after Installing 6.1.1 on Windows 10 64bit
Postby utbluesman » Mon Jul 03, 2017 9:31 pm
Was upgrading to version 6.1.1 because I noticed in the change log that the bug of corrupt Playlist ZIP files was fixed.
Ran across a problem. Any help is appreciated.
Tried to follow the help request best practices below.
Let me know if there is anything else you need.
Thanks.
Problem Description: After upgrading to version 6.1.1 of Subsonic from 5.3.x, receive this error on local PC hosting Subsonic, and remote PCs trying to log into Subsonic on same network.
HTTP ERROR: 404
NOT_FOUND
RequestURI=/index.view
Powered by Jetty://
Subsonic service is running and appears green in Taskbar.
Troubleshooting Steps:
Installed ver. 6.1.1 over top of prior version (5.3). Rebooted PC.
Encountered error message.
Uninstalled 6.1.1, Uninstalled JAVA, rebooted PC.
Installed 6.1.1, installed JAVA 8.31 as part of Subsonic installation.
Rebooted PC
Still having problem.
Completely removed ver 6.1.1 and reinstalled 5.3.x.
Previously worked on 5.3.x before upgrade to 6.1.1.
Now, same error on 5.3.x
Playback Application and version: Logging into Subsonic through Google Chrome via IP address and port from another PC on the same network.
Subsonic Version: 6.1.1 Build fc853b
Server Version: Cannot get to web interface to find server version.
Hardware Platform: Windows 10 Home 64bit running on Acer Aspire R3610 (Intel Atom 330) with 4GB RAM
Java Memory Limit: Set to 250MB
Problem Filename: n/a
Output from ffmpeg -i: n/a
Last ten log file lines:
- subsonic-agent.log -
487 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@6e1b77: display name [org.springframework.context.support.ClassPathXmlApplicationContext@6e1b77]; startup date [Mon Jul 03 16:00:07 CDT 2017]; root of context hierarchy
1347 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-agent.xml]
4941 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@6e1b77]: org.springframework.beans.factory.support.DefaultListableBeanFactory@8806ef
5148 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@8806ef: defining beans [service,agent,frame,settingsPanel,statusPanel]; root of factory hierarchy
Executing: subsonic-service.exe -stop
61058 [pool-1-thread-1] WARN org.springframework.remoting.rmi.RmiProxyFactoryBean - Could not connect to RMI service [rmi://localhost:9412/SubsonicDeployerService] - retrying
Executing: subsonic-service.exe -start
- subsonic-service.log -
279 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@1607bb6: display name [org.springframework.context.support.ClassPathXmlApplicationContext@1607bb6]; startup date [Mon Jul 03 16:01:35 CDT 2017]; root of context hierarchy
881 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
4117 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@1607bb6]: org.springframework.beans.factory.support.DefaultListableBeanFactory@16178c5
4244 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@16178c5: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
4519 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: C:\Program Files (x86)\Subsonic\subsonic.war
Extracting webapp to c:\subsonic\jetty\fc853b
4888 [main] INFO org.mortbay.log - jetty-6.1.x
10522 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:8083
Subsonic running on: http://localhost:8083/
10836 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
11985 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
12248 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[192.168.1.141:9412](local),objID:[0:0:0, 0]]]]
- subsonic.log (from c:\subsonic folder) -
[2017-07-03 11:36:13,825] INFO MediaScannerService - Scanned media library with 128565 entries.
[2017-07-03 11:36:13,825] INFO MediaScannerService - Marking non-present files.
[2017-07-03 11:36:29,578] INFO MediaScannerService - Marking non-present artists.
[2017-07-03 11:36:29,674] INFO MediaScannerService - Marking non-present albums.
[2017-07-03 11:36:30,651] INFO MediaScannerService - Completed media library scan.
[2017-07-03 11:36:37,567] INFO PlaylistService - Starting playlist import.
[2017-07-03 11:36:37,631] WARN PlaylistService - Failed to auto-import playlist F:\! - Playlists\Ben Folds and Charlie Musselwhite - Get Up.m3u. No songs in the playlist were found.
[2017-07-03 11:36:37,647] INFO PlaylistService - Completed playlist import.
[2017-07-03 12:04:40,456] INFO NetworkService - Successfully forwarding port 8083.
[2017-07-03 13:06:49,038] INFO NetworkService - Successfully forwarding port 8083.
[2017-07-03 14:08:57,507] INFO NetworkService - Successfully forwarding port 8083.
utbluesman
