MariaDB or MySQL support when using the WAR deployment
Postby redranger » Mon Dec 18, 2017 10:33 pm
Hi there....
I would like to run Subsonic on the MariaDB server v.15.1 Distrib 5.5.57, that comes with my QNAP TS251+ firmware v.4.3.3. Is that supported? If so, how can I configure the JDBC URL as described here > http://www.subsonic.org/pages/database.jsp
Any help is highly appreciated. Thank you very much.
Props 8)
Thank you for your help.
Regards!
/Redranger
redranger
Re: MariaDB or MySQL support when using the WAR deployment
Postby redranger » Tue Dec 19, 2017 9:14 pm
This looks promising > https://stackoverflow.com/questions/348 ... with-mysql <-- However. Trying it does not make Subsonic use MySQL. Any advice on how to make Subsonic on QNAP (WAR deployment in Tomcat) or another Busybox using device utilize MySQL?
Regards!
/Redranger
redranger
Postby redranger » Sat Dec 23, 2017 7:38 pm
Anyone?
Regards!
/Redranger
redranger
Postby redranger » Tue Jan 02, 2018 11:04 pm
Is there really no one that has bumped into this challenge before. Any help would be highly appreicated.
Thank you so much.
Regards!
/Redranger
redranger
Postby lonesomerider » Wed Jan 03, 2018 11:24 pm
Took my a while to have some time to try this myself :wink:
and found that by putting a setenv.sh file in the Tomcat bin folder does what you need (This is for linux, on Windows you would have a setenv.bat and a SET CATALINA_OPTS= line)
#!/bin/sh
echo $CATALINA_OPTS
export CATALINA_OPTS="$CATALINA_OPTS -Dsubsonic.db=jdbc:mysql://localhost:3306/subsonic\?user=subsonicDbUser\&password=VeryStrangePasswordNobodyWillEverFindOut\&characterEncoding=UTF-8"
echo $CATALINA_OPTS
the echos are just for testing, not really needed.
You have to do additionally the following steps:
chmod +x setenv.sh
chown UserUsedForTomcat setenv.sh
and then restart the Tomcat server.
If you use something different than Tomcat, pls. post YOur results, too.
/lonesomerider
lonesomerider
Postby redranger » Thu Jan 04, 2018 10:00 pm
Thank you so very very much @lonesomerider ... it works :-) ... loving it!
Regards!
/Redranger
redranger
