systemd service file for Subsonic
Postby Stormwind » Thu Apr 25, 2019 5:59 pm
For those of us running subsonic in a systemd based Linux distro (like Fedora in my instance), I created a systemd service file for subsonic.
It assumes it will run subsonic user/group subsonic, and the sysconfig file assumes /mnt/Audio for audio file location and a https port - customize to your own needs.
Hope it saves someone some time!
subsonic.service:
[Unit]
Description=Subsonic media streame
Documentation=http://www.subsonic.org
After=network.target network-online.target
Wants=network-online.target
[Service]
Type=simple
User=subsonic
Group=subsonic
EnvironmentFile=/etc/sysconfig/subsonic
PIDFile=/run/subsonic/subsonic.pid
Environment=JAVA_HOME=/etc/alternatives/jre_1.8.0
PassEnvironment=JAVA_HOME
ExecStart=/usr/bin/subsonic --pidfile=/run/subsonic/subsonic.pid $SUBSONIC_ARGS
[Install]
WantedBy=multi-user.target
/etc/sysconfig/subsonic:
# For example, to specify that Subsonic should use port 80 (for http)
# and 443 (for https), and use a Java memory heap size of 200 MB, use
# the following:
# SUBSONIC_ARGS="--port=80 --https-port=443 --max-memory=200"
SUBSONIC_ARGS=--port=8124 --https-port=8125 --max-memory=150 --home=/var/subsonic --default-music-folder=/mnt/Audio/Music --default-podcast-folder=/mnt/Audio/Podcasts --default-playlist-folder=/mnt/Audio/Playlists
Stormwind
