I realized that don't show all the library.. when I perform a new scan .. the result is only 1/3 of the complete library.
The nfs permissions are correct, from the terminal the raspberry correctly show all the files that I don't see in subsonic.. also I have done on all the library a chomod -R 777 and also verified a user and group ownership with a big chown to be sure.
I see logs like this
- Code: Select all
[7/21/19 10:39:13 PM UTC] ERROR RESTFilter Failed to write error response.
[7/21/19 11:52:00 PM UTC] WARN RESTFilter Error in REST API: /media/multimedia/o3765977.jpg (No such file or directory)
[7/22/19 2:13:51 AM UTC] WARN RESTFilter Error in REST API: NullPointerException
[7/22/19 11:27:44 AM UTC] ERROR MediaScannerService Failed to scan media library.
[7/22/19 11:27:45 AM UTC] INFO PlaylistService Starting playlist import.
[7/22/19 11:27:45 AM UTC] INFO PlaylistService Completed playlist import.
What I can do?
Thank you.
