Issue Connecting to my Laptop
Postby pinkfloydfan123 » Thu Oct 24, 2019 1:01 am
Hello. I will admit that I'm a novice here, so I'll apologize in advance for any dumb questions.
I downloaded Subsonic onto my desktop and was able to get everything working fine. I can access my music from any computer and my dSub on my phone. Life is great. My desktop is running Windows 10.
In talking to a friend of mine at work he has a laptop with Windows 7 set up to be his "server" and he just lets it run. So, I have an older laptop that I cleaned off, installed Windows 7 (64-bit) and was intending to use this as my "server." The only thing other than Windows 7 on the laptop is the Subsonic program. I went in and created a user to test, but when I tried to log onto that user (either from my desktop or dSub) I get connection errors.
Again, everything works from my Desktop, but doesn't from my laptop. Also, I am using an external hard drive with my laptop, but not my desktop. I'm not sure if that makes a difference.
I'm confident it's a network setting on my laptop that I need to change. But for the life of me I can't figure it out.
Any ideas?
Thanks (in advance).
pinkfloydfan123
Re: Issue Connecting to my Laptop
Postby G8DHE » Thu Oct 24, 2019 8:59 am
By default the Windows firewall will probably be blocking incoming requests ?
Geoff G8DHE
Version 6.0 Beta 2
G8DHE
Postby pinkfloydfan123 » Thu Oct 24, 2019 2:51 pm
Thank you for your reply.
I had thought that to be the case and had shut down the Windows Firewall. Still no success.
pinkfloydfan123
Postby G8DHE » Thu Oct 24, 2019 3:13 pm
So your browser on the laptop can connect and configure, but browsers on the same network get what sort of error when connecting ?
Geoff G8DHE
Version 6.0 Beta 2
G8DHE
Postby pinkfloydfan123 » Fri Oct 25, 2019 12:38 pm
So, on a whim, I installed Windows 10 on my laptop and now everything works fine on my laptop. I have no idea why, but it's working and that's all that matters. :)
Thanks for the replies!
pinkfloydfan123
