Raspberry Pi. Raspbian, Java, Jukebox
Postby mcyzyk » Thu Jun 18, 2020 6:16 pm
FYI, running OpenJDK Java 8 on Raspbian (32-bit Debian Butch for ARM).
Jukebox does not work.
I'm seeing a lot of issues with this, and how the old Oracle Java 8 used to solve it.
Will Jukebox ever work on anything other than Oracle's Java 8 JRE?
Mark
mcyzyk
Re: Raspberry Pi. Raspbian, Java, Jukebox
Postby mcyzyk » Tue Jun 30, 2020 8:43 pm
Ok, I've installed Java 8, OpenJDK.
Also, I found this tutorial over at AirSonic:
https://airsonic.github.io/docs/jukebox/
I ran that Java program and here is the output:
pi@raspberrypi:~ $ java audioDevList
Available mixers:
PulseAudio Mixer
default [default]
Headphones [plughw:0,0]
Audio [plughw:1,0]
Port Headphones [hw:0]
Port Audio [hw:1]
So far, in my JRE sound.properties file, I've tried "hw:1" and "plughw:1.0". (My sound card for this is an external DAC plugged into USB.)
No joy!
Sure would be great if Subsonic Jukebox worked on OpenJDK.
mcyzyk
Postby ebasta » Thu Jul 09, 2020 8:53 pm
OpenJDK on Pi's and similar have always had issues. The official Oracle release works fine. I haven't tried anything higher than 8.
ebasta
Postby mbro » Sat Feb 20, 2021 1:58 am
I have Subsonic running on DietPi on a Pi4.
Running the audioDevList java script, my output shows:
Available mixers:
PulseAudio Mixer
ALSA [default]
ALSA [plughw:0,0]
ALSA [plughw:0,1]
ALSA [plughw:0,2]
Port ALSA [hw:0]
Snippet from my subsonic.sh file:
${JAVA} -Xmx${SUBSONIC_MAX_MEMORY}m \
-Dsubsonic.home=${SUBSONIC_HOME} \
-Dsubsonic.host=${SUBSONIC_HOST} \
-Dsubsonic.port=${SUBSONIC_PORT} \
-Dsubsonic.httpsPort=${SUBSONIC_HTTPS_PORT} \
-Dsubsonic.contextPath=${SUBSONIC_CONTEXT_PATH} \
-Dsubsonic.db="${SUBSONIC_DB}" \
-Dsubsonic.defaultMusicFolder=${SUBSONIC_DEFAULT_MUSIC_FOLDER} \
-Dsubsonic.defaultPodcastFolder=${SUBSONIC_DEFAULT_PODCAST_FOLDER} \
-Dsubsonic.defaultPlaylistFolder=${SUBSONIC_DEFAULT_PLAYLIST_FOLDER} \
-Djava.awt.headless=true \
-verbose:gc \
'-Djavax.sound.sampled.SourceDataLine=#ALSA [plughw:0,0]' \
-jar subsonic-booter-jar-with-dependencies.jar > ${LOG} 2>&1 &
You can see the 2nd last line referencing ALSA [plughw:0,0] and that works for me!
Jukebox mode works for me!
mbro
