move jetty/other stuff from c:\subsonic to another drive
Postby perler » Mon Jul 20, 2009 5:43 pm
hi,
i installed subsonic on a dumb terminal with a very small c:\ partition, which i cannot resize. i need to move the content from c:\subsonic somewhere else. is this possible?
PAT
perler
Postby 3R3 » Tue Jul 21, 2009 3:24 am
if you use the standalone version, its just a matter of moving the folder, since it is self-contained. if you used the windows installer on the other hand, i remember there's "c:\subsonic" AND "c:\program files\subsonic" so both schould be moved and the path of the shortcut in the start menu has to be changed too.
3R3
