Subsonic users running on FreeNAS
Postby kapz » Fri Nov 13, 2009 8:28 pm
Without going into too much detail. Has anyone that is running Subsonic on FreeNAS had any issues when listing sub-folders (left panel) for music paths with a large number of sub-folders (800+)?
My hardware is a AMD Sempron 140 Sargas 2.7GHz (single core) + 2GB RAM
Paid Subsonic user
Love my unRaid (~9.5TB): [url=http://lime-technology.com/forum/index.php?topic=2031.msg40351#msg40351]Pictures Here (Reply #82)[/url]
kapz
Postby sgx1 » Fri Nov 13, 2009 9:00 pm
I'm approaching 600 folders on mine. I'm using an embedded VIA 1.5GHz processor and 512MB RAM, and it works great. 800+ shouldn't be an issue with the hardware you've listed. The only time you'd see a delay is when you add a new music folder, or refresh the list. Once it's refreshed, it loads up like normal.
sgx1
Postby kapz » Fri Nov 13, 2009 10:28 pm
sgx1, do you happen to know what command is being used to mount your disks?
Paid Subsonic user
kapz
Postby sgx1 » Fri Nov 13, 2009 11:12 pm
FreeNAS is installed on a standard IDE drive, partition 2 of that drive is a ufs-formatted partition.
My main music folder is on a ufs-formatted SATA drive mounted in FreeNAS.
My second music folder is an NFS mount to another NAS, which can only be done at the FreeNAS terminal using the mount_nfs command:
mount_nfs 192.168.1.100:/volume1/music /mnt/ds_music
I created a PostInit entry to mount the drive at boot, but haven't rebooted FreeNAS since, so I don't know if it mounts that drive before SubSonic starts up.
I hope that answers your question.
sgx1
