Play all option?
Play all option?
Postby wwest » Fri Nov 20, 2009 2:49 pm
Good day, i am wondering if there is a way to play everything without having to add everything i have to the play list? A side from adding all my music into a folder and then adding the whole folder
What i would like to do is just listen to everything i have without the effort of adding. I know it sounds lazy but with a lot of music adding it can be a pain lol
Thanks in advance
wwest
Postby sindre_mehus » Fri Nov 20, 2009 6:24 pm
There is currently one way of doing this:
1. Change the player type to "External player" (in Settings > Players)
2. Then go to More > Random Playlist. Select the "Play more random songs when end of playlist is reached" checkbox and click OK.
Hope this helps,
Postby wwest » Fri Nov 20, 2009 6:41 pm
I will check that out when i get home but it doesn't sound like what I'm looking for and i think i may of explained it badly lol
I would like to play all the albums/artist's i have listed in the left hand column without going threw 1 by 1 and adding each of them. Kind of like a master playlist.
I have my music setup as D:\Music\artist\album\songs.mp3
Is there a way to create a play list that grabs everything with the D:\Music directory?
wwest
Postby wwest » Sat Nov 21, 2009 1:55 am
I figured it out
I edited the play list to load directories instead of file
instead of
d:\music\artist\album\song.mp3
I replaced it with
d:\music\artist\
It was actually pretty simple. I opened a command window and then navigated to D:\Music and ran
dir /b /s >d:\file.txt
Then once it was finished i opened up the text file and edited it to reflect the directories i wanted and deleted the rest. Then i saved the files to D:\Music\Playlist and named it "Master List.m3u" Takes a minute or two to load but its worth it.
Thank you for your help :D
wwest
Postby Sh4gr4th » Mon Nov 30, 2009 12:37 pm
sindre_mehus wrote:Hi,
Hope this helps,
Is it just me or is there no checkbox?
Edit: Okay, I stumpled upon it now. Party mode was enabled...
Sh4gr4th
Re:
Postby jannoke » Sun Apr 08, 2012 8:13 am
wwest wrote:I figured it out
instead of
I replaced it with
d:\music\artist\
Sorry..but this is crazy.. I have like gazillion folders. Editing all the lines by hand is not very good solution. Instead you can specifig attribute option and define to show only directories by default:
dir /b /s /A:D >All.m3u
And there you go - all ready playlist. You can add it to windows tasks so it will be created every night just like rest of the indexing.
Also loading playlist WILL TAKE TIME if you have a lot of files (12 000 files in my case). It took about 3 minutes to load them all. Also you might need to change the memory limit from 100MB to something more reasonable. It needed 180MB in my case to load the files. Otherwise it just loads and completes without a result.
Hope it helps.
jannoke
