changing statistics manually
Postby diab0lik » Tue Nov 24, 2009 12:42 pm
hi is there anyway i can just the user statistics manually? ie the amount downloaded, streamed per user etc thanks
diab0lik
Postby M0NG0 » Thu Nov 26, 2009 2:16 am
Yep, with SQL you can. Go to http://[your_Subsonic_URL]:[your_port]/db.view and enter the following query to see the user table:
SELECT * from user
This will show the user table. Let's say you want to set a user named diab0lik to show 0 bytes streamed. You can do that with the following query:
UPDATE user
SET BYTES_STREAMED='0'
WHERE USERNAME='diab0lik'
M0NG0
