[SOLVED] XML API Failure
Postby toxic » Fri Nov 27, 2009 4:07 am
It's in the title...
I have the latest version of Subsonic, I'm running it on ubuntu karmic, with the standalone web server...
[EDIT] Please, don't feel offended, as I re-read my post, i thought you could feel so... So I'm saying it loud once here : I think you've done a great job with Subsonic ! It's the most advanced job I've seen so far in this area ! So, really, I love your job, just the "shiny GUI" is not at my taste... That's why I'd like you to correct some bugs... Well just read the post...
[/EDIT]
The thing is that I really "hate" your way of managing directories ! I'd like to have my entire directories flatten, and sort the music on a iTune-Like way : list the artists or the albums, but not the file-structure...
So I thought I could use your API to make myself my own web-client, avoiding the slow standalone webserver or any other problem regarding tomcat (I really LOVE apache, and php is my world ! And I only had troubles with tomcat and JAVA...)
Notice that frames are VERY UGLY, first they bring with them lots of compatibility issues, but they also are ugly on a screen (set up your firefox to be as if you had a 1024x768 screen... You'll understand...
[EDIT2]Think about it : If you provide me with a functionnal XML API, I may be able to come up with some alternative GUI for Subsonic, and as I'm a great fan of Ubuntu, I might also package it for ubuntu, allowing you jub to spread easily to any Ubuntu-user ! Sure you'd like that !
[/EDIT2]
So I tried out the api, and by the simple command to list a directory :
http://xxx.xxx.xxx.xxx:8080/subsonic/re ... 4e49534544
[EDIT3]The directory I tried to list actually contains LOTS of subdirectories and files, but that should in no way be an Issue... And This directory is perfectly listed on the standalone-webserver (your GUI).
[/EDIT3]
I got an error... So here the result :
Error
Subsonic encountered an internal error. You can report this error in the Subsonic Forum. Please include the information below. Exception   java.lang.NumberFormatException
Message   For input string: "2f6d656469612f446174612f4d757369632f4f5247414e49534544"
Java version   Sun Microsystems Inc. 1.6.0_15
Operating system   Linux 2.6.31-14-generic
Server   jetty-6.1.x
Memory   Used 37 of 70 MB
Stack trace   java.lang.NumberFormatException: For input string: "2f6d656469612f446174612f4d757369632f4f5247414e49534544"
   at java.lang.NumberFormatException.forInputString(NumberFormatException.java:48)
   at java.lang.Integer.parseInt(Integer.java:458)
   at java.lang.Integer.parseInt(Integer.java:499)
   at net.sourceforge.subsonic.controller.LeftController.saveSelectedMusicFolder(LeftController.java:160)
   at net.sourceforge.subsonic.controller.LeftController.getLastModified(LeftController.java:77)
   at net.sourceforge.subsonic.controller.RESTController.getIndexes(RESTController.java:147)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
   at java.lang.reflect.Method.invoke(Method.java:597)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
   at net.sourceforge.subsonic.security.RESTRequestParameterProcessingFilter.doFilter(RESTRequestParameterProcessingFilter.java:108)
toxic
Re: XML API Failure
Postby sindre_mehus » Fri Nov 27, 2009 8:00 am
toxic wrote:So I tried out the api, and by the simple command to list a directory :
You're using an invalid value for 'musicFolderId'. To get the list of valid values, use the getMusicFolders.view method.
Cheers,
Postby toxic » Fri Nov 27, 2009 10:47 pm
Well, in fact, it seems you have stragne conceptions about MusicFolder and MusicDirectory or something like that...
Anyway, I finally got to understand how your API's working... seems not to have failures in the end...
Thanks for the help anyway !
I will maybe report in another thread once I got a "suitable" php gui...
Note : It seems that to be able to make a directory-flatten and Album-Based GUI, I'll just be able to use subsonic as a streaming server... I'll need a Database on my own...
toxic
