Playlist is empty error
Postby abhiroopb » Thu Dec 24, 2009 11:04 am
I have set-up Subsonic to work as a web based player. Currently I am only using it on the same computer as the music for testing purposes.
I have changed the playlists folder (in the web based players settings) to point to the folder where my .m3u playlists are saved. These are playlists I created in amarok and saved as .m3u. I would like to import these playlists into Subsonic.
I click on "more actions" (bottom right), then on "Load" (which is under the playlist heading). Here I see the list of all my playlists. I then click on "Load" next to a playlist and it reverts back to the "Now playing" song list and at the bottom I see the error: "Playlist is empty".
What am I doing wrong?
abhiroopb
Playlist empty
Postby triumph » Thu Dec 24, 2009 9:22 pm
If you are using playlists created by MS Windows they can't be read by Unix/Linux systems as the \ is a / in the path name and the full path will be different. Also check the permissions on the playlist location.
Hope this helps.
triumph
Postby abhiroopb » Fri Dec 25, 2009 3:06 am
I am using amarok in Ubuntu 9.10.
abhiroopb
Same problem
Postby RickHurst » Fri Apr 09, 2010 4:57 am
I am having the same problem. Did you ever get it figured out. I put the m3u files in the c:\playlists folder and it shows up when I load the playlists. When I select any one of my playlists, it comes up empty. Any answers?
RickHurst
Postby kyler1 » Mon May 03, 2010 8:19 pm
I am also having the same problem, have the playlist folder set to
D:\My Documents\My Music
where my playlist are stored in .m3u, and work on mediamonkey on local computer
when I try to access them via subsonic more actions ->Load->Load it displays a empty playlist.
Any help is appreciated
EDIT: Just found the solution elsewhere http://forum.subsonic.org/forum/viewtopic.php?t=1808 seems to be a problem with absolute path
kyler1
