subsonic.org address
Postby alphawave7 » Thu Feb 11, 2010 10:00 am
How/where to I set up my subsonic.org address for dynamic hosting? (Yes, I'm a paid donor). TIA!
Postby sindre_mehus » Thu Feb 11, 2010 11:44 am
Settings > Network
Cheers,
Postby VintageGold » Fri Feb 12, 2010 1:42 am
That was my first question after upgrading to 3.9, thanks. 8)
Thought of the Day: They say the best things in life are free, but are all free things the best?
VintageGold
Postby alphawave7 » Mon Feb 15, 2010 3:34 am
It now says
Status: yourname.subsonic.org is registered, but could not connect to it. (NoRouteToHostException)
What now...is there a specific port? I have it streaming over dyndns, so I know it works, but not at the subsonic address using the existing port.
Postby alphawave7 » Thu Feb 18, 2010 7:48 am
Addy still unresolvable. Do I need a port opened? My dyndns has a specific port opened...could I not just use the same port?
Postby kdid » Thu Feb 18, 2010 11:04 pm
You just do specify the same port as you use with dyndns. That was what I did, and I now can use either adresses to connect to my music box.
-- kdid
kdid
hi
Postby buellie » Fri Feb 19, 2010 4:25 am
when you register your domain...is there a waiting time for it to work?..
i started it but i couldnt connect internally and my daughter couldnt connect externally
does the upnp need to be checked for subsonic.org to work?
or can that stay unchecked?
appreciate the help
buellie
Postby kdid » Fri Feb 19, 2010 7:34 am
For me it worked right away, and I believe it is ment to do that.
If you have not manually set up port forwarding, you will need to check upnp and hope that your router have been configured to support it.
In most routers there is a toggle to activate upnp.
Note that the port specified in the "Subsonic Configuration Tool" must be the same as the one specified in the "Settings->Network" tab in subsonic.
Personally I am not that in favor of using upnp in the router because I imagine that malware more easily can set up a port for remote access to the computer through that. But I guess basic firewall programs on each machine should prevent malware from requesting such a port. - Maybe I am mistaken here and this is not a problem.
-- kdid
kdid
Postby buellie » Fri Feb 19, 2010 6:19 pm
getting that doesnt work internally or externally
buellie
Re: subsonic.org address
Postby deftdrummer » Mon Oct 31, 2011 2:07 am
I too have this same problem. Won't work on my iPhone or iPad as it used to. I have automatic port forwarding set up, and even have the port forwarded in my router's settings but it still doesn't work. I didn't do anything to the settings prior to the server's malfunction.
I really love Subsonic but I can see myself using iTunes Match is looking better and better each day.
deftdrummer
Postby alphawave7 » Mon Oct 31, 2011 5:33 am
deftdrummer wrote:I too have this same problem. Won't work on my iPhone or iPad as it used to. I have automatic port forwarding set up, and even have the port forwarded in my router's settings but it still doesn't work. I didn't do anything to the settings prior to the server's malfunction.
You'll need to test with canyouseeme.org using your chosen port # to ensure it's available over the WAN. If canyouseeme cannot see you, neither can any apps. Often, a reboot of the router after making any changes fixes this, but I can also say an outage/reboot of the router can also cause this, as it did for me, in inclement weather. If automatic forwarding isn't getting the job done, you'll need to do so manually. G'Luck!
