upgrading to 3.9, deleted Work symbolic link (linux) ...oops
Postby anitract » Fri Feb 12, 2010 6:28 am
I misread the upgrade instructions for the tomcat/war version and deleted the actual symbolic link called Work that was located in /var/lib/tomcat5.5
Problem is I have no idea where this was pointing and subsonic now crashes when launched as it seems to need that linked folder. Ideas on where the Work folder was pointing?
anitract
Postby anitract » Fri Feb 12, 2010 2:23 pm
I guess what I am really looking for is someone with a linux + tomcat setup to check the path that symbolic link is pointing so I can recreate it on my system. I use ubuntu, by the way. Thanks!
Edit: Here is the actual error I get:
java.io.FileNotFoundException: /var/lib/tomcat5.5/work/Catalina/localhost/subsonic/org/apache/jsp/WEB_002dINF/jsp/login_jsp.java (No such file or directory)
anitract
Postby anitract » Fri Feb 12, 2010 3:05 pm
nevermind i was able to find the directory, which was /var/cache/tomcat5.5, and create the symbolic link
all good now
anitract
