Error: Didn't understand the reply. Please check the server
Postby sprbc753 » Sat Apr 03, 2010 2:53 am
Please check the server address.
So I am getting this error on my Android phone, but only when i'm not on WIFI. If I attach to my home network via wifi, i am able to stream and see the music, but not when i try via the 3G connection.
Any advice? Do i need to disable a firewall?
I have a subsonic.org address as well....
sprbc753
Postby kingichrist » Sun Apr 04, 2010 1:03 am
same here.. any suggestions?
kingichrist
Postby Tanner Williamson » Tue Apr 06, 2010 4:52 am
May I suggest you post your Service Provider & applicable plan and features, the phone make and model, and the software version (phone OS).
Tanner Williamson https://www.tannerwilliamson.com/
Tanner Williamson
Postby kingichrist » Wed Apr 07, 2010 2:06 am
Sprint, everything is unlimited..
Samsung Moment Running latest Android OS
kingichrist
Postby sprbc753 » Sun Apr 11, 2010 3:14 am
Solved it sorry for the late reply, i had to open my port for that address UDP
sprbc753
Postby kingichrist » Sun Apr 11, 2010 3:17 am
did you open the port on your router or your phone? I have the port open on my router already.. most of the time I can stream music but now it will time out when I try to load a play list from my phone.
kingichrist
Postby cooperg21 » Mon Apr 26, 2010 7:22 am
I have a Motorola Droid on Verizon with an unlimited plan. Everything was working great when I was around my house on 3g (not wifi) and it was working when I was about a mile away. However, now that am at work about 10 miles away, it isn't working... Maybe it is because I am now using a different satellite?
Getting the exact same error....
Oh yea, and when I test the connection on my phone it says that it connects fine...
Please help!!!
cooperg21
