Playlist isn't loading
Postby RickHurst » Fri Apr 09, 2010 4:58 am
I am having a problem with the playlists. I put the m3u files in the c:\playlists folder and it shows up when I load the playlists. When I select any one of my playlists, it comes up empty. Any answers?
RickHurst
Postby RickHurst » Fri Apr 09, 2010 5:06 am
By the way, I created the playlists in Media Monkey and exported them in an m3u format. They show up, but when I select them, they just show empty.
RickHurst
Postby mlody11 » Sun May 16, 2010 4:32 am
I had the same problem when exporting/importing playlists with media monkey and subsonic. The thing you have to do is set the path to the music folders to the same between subsonic and media monkey. In other words, if you media monkey is monitoring \\unc\music, subsonic has to be set to \\unc\music for the playlists to import properly otherwise it just bombs out because it can't find the file. If its a drive letter, the drive letter and path have to be the same.
Warning: Playlists with 500+ songs may take a bit to load although it appears they are not loading. Also, if using a unc, make sure the subsonic service is using an account that can access the unc.
Hope that helps!
mlody11
