Not able to play .wma files through Flash Player.
Postby vignesh_mj » Wed May 05, 2010 8:11 am
vignesh_mj
Re: Not able to play .wma files through Flash Player.
Postby maestro » Sat May 15, 2010 8:24 pm
vignesh_mj wrote:Not able to play .wma files through Flash Player.
Vignesh, I could be wrong, but I believe the flash player only handles MP3, so if you turned off transcoding, that may be the cause. I know I thought I could stream vorbis, but it turns out that's not the case. I'll probably just switch to flac....if it's going to transcode, might as well start with the lossless source files.
maestro
