Guess I'm going to need some handholding: Windows/Android
Postby cabbie » Wed Jul 07, 2010 1:45 am
While on the same wifi network, I can get my Android phone to stream from my W7 computer. I then attempted to connect via 3G and when that failed, I tried a separate wifi network, which also failed.
The router is 2Wire 3800HGV-B and my service is AT&T U-Verse. I followed the general guide for this router here.
I set up a firewall exception for Port 80 and I get "Connection Failure. Connection to http://xxx.xxx.xxx.xxx:80 refused."
In the web interface, I have it set to forward to my custom server (will be happy to donate if I ever figure this out) and it says it responds successfully. It does not find my router at all.
Where to from here? TIA :)
cabbie
Re: Guess I'm going to need some handholding: Windows/Androi
Postby mr3man » Wed Jul 07, 2010 3:04 am
Most ISP's don't allow you to host a server on port 80. Try using another open port, adjust your firewall rules, and change it under "settings" in the subsonic control panel. Make sure to restart subsonic and your router after you make the changes.
mr3man
Postby cabbie » Wed Jul 07, 2010 3:06 am
Will do. Is there a port that people have had success with that are in a similar situation? Not sure how to pick besides rolling a D100 :D
cabbie
Postby mr3man » Wed Jul 07, 2010 12:10 pm
I use 9000. Works for me.
mr3man
Postby ccandreva » Wed Jul 07, 2010 2:13 pm
The default port for linux Subsonic installed is 4040
ccandreva
Postby cabbie » Wed Jul 07, 2010 10:04 pm
Set it to port 9000, rebooted phone, computer and router, and it works! I'm VERY happy now.
I'm going to test this app thoroughly and at the end of the trial, if its doing what I need, I'll happily donate 14 bucks to bridge the gap between now and gingerbread OTA music streaming.
Thanks guys! Image
cabbie
