How to choose what types of files will be downloaded.
Postby caata » Thu Sep 02, 2010 10:45 am
Hi there,
It's there any possibility to select what types of files will be included in the archive?
For example in the album folder i have .mp3 .m3u .pdf .jpg .txt and when i hit download, the archive will contain only .mp3 .m3u and .jpg.
It's possible? any tricks?
Thank you.
caata
Postby nipar » Sun Nov 14, 2010 12:19 pm
After some digging, the only way I can see you downloading non-music and non-jpg files is to change the music file mask. You'll find it under Settings>>General.
Just add the whatever file extension you require.
The BIG problem with it is when you add the non-music file to a playlist (using for instance "play all" or "add album") your player will jam when it tries to play the file. If you are the only one using your music server you can get away with it by being careful.
nipar
