Sub Air Not showing Songs from Some Folders
Postby rk3264 » Fri Sep 24, 2010 12:25 am
I have been playing around with Subsonic and the SubAir. What I noticed is that SubAir does not list songs in some of the directories. When I Access the same thru the WEB Interface, there is no issue.
What I think is that when the Directory has hyphen (-) and the Brackets, then it is not showing list of songs under that directory.
Can some one see if they can replicate this issue and provide a possible solution.
Thanx
RK
rk3264
Postby tj78492 » Fri Sep 24, 2010 2:30 pm
The problem is it doesn't list music files in a directory if it contains sub directories.
Example Folder A contains Folder B, Track-C.mp3, and Track-D.mp3
Neither of the MP3 files will show up
I wish that was fixed. :cry:
tj78492
Postby rk3264 » Fri Sep 24, 2010 4:31 pm
Hi tj78492,
Thanx for Pointing out the root cause. Now I verified and it is infact not showing files when there is sub directory. In some of the music folders, I have created a sub directory where all the Cover Info jpeg files were stored.
Hope the developer takes note of this and fixes this issue.
ramana.
rk3264
