I've seen various post, but no real tutorial/resolution to subject matter of this post.
I have a Windows Vista (32) computer running an installed (donated and registered) the latest version of Subsonic. I have Norton 360 running with the Subsonic services "allowed". Trying to set this up for access on my laptop (both at home and away) and for isub app on my iphone (iOS 4).
In Subsonic Contol Panel I use Port 4040 (my Server address: http://localhost:4040). In Network Settings I have it to "Automatically configure your router..." selected; the status indicates that it is successfully forwarding port 4040.
However, I get the following message when selecting: "Access your server..." Status: xxxx.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException).
Trying to fix this issue has been frustrating to say the least.
I've tried testing this port at www.yougetsignal.com/tools/open-ports/; it says that its closed. When scanning for All Common Ports it informs me that: no open ports found.
I've tried going to portforward.com. My router is a Linksys WRT54G. That site says that my computer has to be configured for "static IP Address"
I currently have it set up for DHCP. I have a Azurus, Orb and Squeezebox Server, a Linsys WMC extender and Bluray player/netflix successfully running under DHCP.
Long explanation, maybe a simple answer, but is it necessary to go static IP for this application? Do I then have to change the settings for my other applications? Why, when other applications work with DHCP in my setup (most notably Orb which is similar in function) does Subsonic require port forwarding?
Any help would be greatly appreciated.
