New user, have some questions
Postby acme64 » Tue Jan 25, 2011 4:45 am
1: if i add new music to my folder, how is subsonic updated? is it automatic? is there an update button somewhere?
2: how do i enable scrobbling?
3: is there a way to scan what has album art and what doesn't and download it? or do i have to do this manually for every album?
acme64
Postby bushman4 » Tue Jan 25, 2011 1:53 pm
1. The browsing interface should be updated immediately, and the search index will be updated automatically at 2am (if you haven't changed the default) or when you tell it to update.
2. settings->Personal. Enter your Last.fm username and password. Click save.
3. Not that I am aware of... this is better done through another tool I believe, like Tag & Rename or maybe even TagScan.
hth,
Glenn
Postby 3R3 » Tue Jan 25, 2011 3:44 pm
to 3.
you bet the next version of SS will make pigs fly and the sky fall down on our heads ;)
seriously though, there are far better tools for fetching covers, none of which i have used except foobar2000 whis is really good for anything with enough plugins :)
good luck,
3R3
3R3
