Force MP3 to MP3 encoding
Postby dopegroove » Fri Jan 28, 2011 12:02 pm
I think I know what has been happening to some of my mp3s that refuse to play on my Android client.
I think that if I force them to be re-encoded, it will work. I have tried to make and mp3 to mp3 transcode option but it does not seem to work. Is there another way other then ogging my whole library?
dopegroove
Postby stozher » Fri Jan 28, 2011 12:05 pm
Upload this MP3 to Android and check with Android player...
http://forum.subsonic.org/forum/viewtopic.php?t=5121
stozher
Postby dopegroove » Fri Jan 28, 2011 12:48 pm
I don't think this is the reason because when I try to play the song in subsonic, the file that is created in the subsonic folder on the device is 0 kb in size. I converted the same file to mp4 and played it on subsonic with no issues
I do not think lame is encoding the file correctly. Also I bunch of these files so I do not think that will help
dopegroove
Postby stozher » Fri Jan 28, 2011 12:53 pm
Just for test upload not playable MP3 file... my be this files is a broken.
stozher
Postby dopegroove » Fri Jan 28, 2011 1:07 pm
Yep it plays.... I think the issue is on the subsonice server.....
dopegroove
Postby stozher » Fri Jan 28, 2011 1:34 pm
Check also if this files at 48 kHz or other sample rate. Post log after attempt to play this files.
stozher
Postby dopegroove » Sun Jan 30, 2011 4:16 pm
I have a number of old MP3's that are like this. Is my only solution to reencode? Ones that I have have made and others from podcasts that I download.
Is there no way to for mp3 to wav and then wav to mp3?
dopegroove
Postby stozher » Sun Jan 30, 2011 7:04 pm
Send example file to my e-mail...
stozher
Postby dopegroove » Tue Feb 15, 2011 12:57 pm
I have sent dropbox link to a file that I have issues playing in subsonic on my phone. It appears the download from subsonic fails. The file is zero bytes in size. I have no issues playing it if I download it right to the phone.
I hope this helps
dopegroove
Postby stozher » Tue Feb 15, 2011 5:38 pm
Remove apostrophe from file name and test again. I no other ideas...
stozher
Postby dopegroove » Thu Feb 17, 2011 1:11 pm
Hmmm that did not work
The download that get int the android subsonic folder is zero bytes in size. It is like is failed to start encoding on subsonic.
Her is clip of my log.
[2/17/11 8:00:25 AM EST] INFO PlaylistInputStream dopegroove listening to "Purchased music\01 BegginTEST.mp3"
[2/17/11 8:00:25 AM EST] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\lame] [-S] [-h] [--resample] [44.1] [-b] [64] [e:\media\new songs\Purchased music\01 BegginTEST.mp3]
Does the andriod subsonic player stream ogg? Maybe I can for transcoding to that....
dopegroove
Postby smallfish » Thu Feb 24, 2011 8:28 am
smallfish
