Export playlist from Winamp to Subsonic
Postby partizan92 » Tue Feb 15, 2011 2:53 pm
What's the best way to export a Winamp playlist to Subsonic? I use Winamp on my home PC and like to use it to create playlists but I would like to be able to listen to those from anywhere. I opened a playlist and did an export to my music folder where my Subsonic playlists are and saved in the same format *.m3u if I recall correctly and it shows up on the Subsonic end but when I load it, no songs appear.
Any ideas?
partizan92
Postby stozher » Tue Feb 15, 2011 5:40 pm
Open playlist with Notepad and compare path of files with playlist created from SS...
stozher
