Is it possible to use a domain at two computers?(not simult)
Postby Arkady.es » Thu Mar 24, 2011 8:05 am
Hello. I have the same music at the PC and in the laptop and I want to use the laptop as a server while the PC is turned off.
-It will give problem with the license?? I'm worried about it and I don't want to try yet
- If I sync the C:\subsonic folders between the two computers the configuration (and the users) will be the same, isn't it?
Arkady.es
Possible (maybe), but certainly not practical
Postby grant420 » Fri Apr 29, 2011 12:58 am
Just install (and donate to Sindre) another instance of the subsonic app on the laptop, pointing to the same files which I assume are on a drive shared by both.
Otherwise you have two apps simultaneously hosting same data on same network anytime you forget and have both of them on, probably not an ideal plan.
grant420
