Do I Need A Subsonic Server...?
Postby ComfyGray » Thu Mar 24, 2011 6:30 pm
Hi all,
Just a bit unsure...
I understand my PC is basicly acting as a server - but do we need the existence and running of subsonics servers in order to make all this work or does it rely exclusively on using our own PC and connection?
Cheers.
ComfyGray
Postby alphawave7 » Thu Mar 24, 2011 6:50 pm
You run YOUR music server (SS) locally. The donated version OPTIONALLY includes a subsonic.org address which forwards directly to your SS server at home, by using a 'redirect service' provided by Sindre. Does that help explain things? :)
Postby ComfyGray » Thu Mar 24, 2011 6:54 pm
thanks alphawave7, much appreciated.
I think it explains things - I conclude that you do need subsonic.org to be functional for subsonic to work.
Just trying to figure out if ever my music will stop if the subsonic.org addresses go down or are changed.
so basicly - the whole thing does rely on Sindre's servers/addresses.
Cheers.
ComfyGray
Postby alphawave7 » Thu Mar 24, 2011 7:07 pm
ComfyGray wrote:thanks alphawave7, much appreciated.
Cheers.
No, not entirely. Your fixed IP address/port of your server should always provide you access, as well as any DNS-Forwarding service, like dyndns and the sort. :)
Postby ComfyGray » Thu Mar 24, 2011 7:15 pm
thanks again alphawave7
so all this can run without subsonic servers even existing? That is what I wanted to know as I was going to buy a 16GB microSD card to store music on but will gladly spend the money on a subsonic license instead if indeed it does require any outside server/address to run.
Suppose mainly hesitant of being out of town and subsonic addresses changing or suffering downtime and being left without my music - which would be a nightmare for me to suffer.
At least I only have to rely on my own PC serving up the goods although I have noticed that the PC (Windows) based subsonic software does contact other IP addresses for some reason which is quite curious.
ComfyGray
Postby alphawave7 » Thu Mar 24, 2011 7:17 pm
If subsonic.org is down (infrequent, thankfully!) you have those options mentioned above as backup. :) Enjoy!
Postby ComfyGray » Thu Mar 24, 2011 7:18 pm
many thanks :D
ComfyGray
Postby GJ51 » Thu Mar 24, 2011 10:43 pm
I also use my homeserver.com domain to access the server at http://maplegrove.homeserver.com:8084/
There are also other DNS services available on the web.
And, of course, as mentioned, you can always just use your external IP:port#
Final note: the SS.org service is actually on a GoDaddy.com server and should have excellent uptime.
Postby dcuellar » Fri Mar 25, 2011 2:20 am
Would anyone be kind enough to share how I can set up my own server just in case? It would be nice to have an option.
dcuellar
Postby GJ51 » Fri Mar 25, 2011 2:55 am
http://www.java.com/en/download/faq/java_win64bit.xml If you have SS installed, uninstall it and delete the Subsonic directory (Windows).
Disable any DHCP services in any VOIP equipment or other additional routers you have. Only ONE router/device per network should handle DHCP assignments.
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc.
Postby dcuellar » Fri Mar 25, 2011 1:27 pm
Great. Thank you so much! I will try this sometime next week so I don't mess anything up while I'm gone on vacation.
Thanks for the quick response GJ51!
dcuellar
Users browsing this forum: No registered users and 91 guests
