[Android] App is blocking headset control
Postby yecarrillo » Wed Mar 30, 2011 2:46 pm
When installed, android app block my headset control. I can not answer calls with freehands.
Please fix this by add a setting to disable this behaviour (As in Winamp App)
yecarrillo
Postby dookie » Thu Apr 21, 2011 7:04 pm
i have this same issue. subsonic is definitely hijacking the headset controls. I cannot end or answer phone calls using the headset button.
Is there a workaround for this?
dookie
Postby GJ51 » Fri Apr 22, 2011 1:30 am
It works fine on my EVO running stock rom.
Please post your phone details so that others who have similar phones might be able to provide you with an answer.
Postby dookie » Fri Apr 22, 2011 2:52 pm
I have a Samsung Captivate, stock rom, rooted. Running Android 2.1 (I haven't bothered to update to 2.2/2.3 yet.)
Pushing the headset button at any time starts subsonic if it's not running, or mutes/unmutes if subsonic is already playing. At no point am I able to answer/end phone calls witht he headset. It does not start up any other media program when pushing the button.
dookie
Postby GJ51 » Fri Apr 22, 2011 4:50 pm
I believe the Android app is designed for 2.2 or higher.
Postby dookie » Fri Apr 22, 2011 5:37 pm
ok. I have been using 2.1 with the android app for some time now. Main functionality is good. Perhaps I'll go ahead and upgrade to 2.2 and see if that fixes this...
dookie
Postby el_jefe » Wed May 11, 2011 12:01 pm
Hi!
The problem is definitely not in the Android version. I am having the exact same problem across 3 different devices using different versions of Android:
1. HTC Desire using 2.2, stock Sense ROM
2. Samsung Galaxy S at 2.1, stock ROM
3. HTC Desire HD, tested both on stock 2.2 Sense ROM and CyanogenMod 7.x (Gingerbread 2.3.3).
This bug is extremely annoying and makes Subsonic virtually unusable for me. Please fix it ASAP!
el_jefe
Postby bemymonkey » Thu May 12, 2011 1:26 pm
Just untick "Media Buttons" in the settings.
bemymonkey
Postby el_jefe » Thu May 12, 2011 5:35 pm
bemymonkey wrote:Just untick "Media Buttons" in the settings.
That insults my intelligence a bit :-) I've tried that of course, it doesn't work. The thing is, Subsonic hijacks the headset controls immediately after it is installed, even before you open it for the first time and even when it is not running. So there's definitely something wrong in the code.
el_jefe
Postby bemymonkey » Thu May 12, 2011 5:54 pm
Sorry, didn't mean to insult you ;)
Then it's a bug, I suppose. On my device it doesn't seem to be present, though. When Subsonic isn't open, the active media player responds to the buttons without problems...
bemymonkey
Postby GJ51 » Thu May 12, 2011 6:24 pm
How do you shut down SS? Have you checked the Applications tab in Settings on the phone to make sure that SS is not running?
Apologies in advance if I'm insulting your intelligence. :wink:
Postby bemymonkey » Thu May 12, 2011 7:59 pm
I don't shut it down... just press the home button or the back button... :shock:
bemymonkey
Postby GJ51 » Thu May 12, 2011 9:16 pm
My bad. I was attempting to address those having the problem. I don't understand how SS can respond if it's not running. Therefore, I was attempting to verify that users who were having the problem were infact closing the program, preferably by going to the home screen in SS and tapping the x in the circle, which on my phone shuts down the app. You can also go to Settings, Applications, Running Services and veify that SS is no longer running.
but, then again, I'm not having this problem, so what do I know? :wink:
Postby el_jefe » Thu May 12, 2011 9:47 pm
OK, so I just did some extensive testing again and here's what I found.
I don't have the Galaxy S anymore, but I tested this on HTC Desire and HTC Desire HD using both stock Froyo ROMs and CyanogenMod 7.0.2 Gingerbread.
There are two main issues:
1. Right after installing Subsonic I cannot answer the phone with the headset anymore. I was able to reproduce this every time and I tested it on both phones with both ROMs installing and uninstalling the app 5-6 times on each ROM/Phone combination. It works 100% of the cases on both phones.
2. Once you open Subsonic it hijacks the headset controls and they cannot be used for other applications. This issue was a bit trickier to reproduce. It doesn't happen every time. Sometimes I had to uninstall the app before I got the controls back, but sometimes even switching to another app was enough to use the controls for that app. What's even weirder, the option to use or not use the headset in Subsonic seems to not function at all sometimes. E.g. sometimes the app uses the controls even if the option is disabled and sometimes it doesn't use them even with the option enabled. After about an hour of testing I gave up, as I was not able to pinpoint what causes the wonkiness. However there's definitely an issue there.
Any feedback would be appreciated.
el_jefe
Postby el_jefe » Thu May 12, 2011 9:49 pm
bemymonkey wrote:Sorry, didn't mean to insult you ;)
No problem, I was just kidding :) Could you please share with us what device you are using? Thanks!
el_jefe
