Web Server Access Logs?
Postby Ericular » Thu Mar 31, 2011 9:13 pm
Is there somewhere that I can see the IP address of who is logging into my Subsonic server?
I know the logs show username and listening actvity... even user agent info. But I don't see IP address anywhere. I want to have a generic guest login for several people to share, but don't want to go that road if I can never tell which IP they are coming from.
Ericular
Postby nelgin » Fri Apr 01, 2011 1:09 am
As the admin user try going to
http://yourwebsite:port/db.view
You should get a box where you can enter an SQL query.
Enter the following line in the box and click OK.
select username,ip_address,last_seen from player
This lists the username, ip they're from and when they were last on.
I see all my admin logins from home, work and my cellphone, and when I logged in as my friend to check her account.
nelgin
Postby Ericular » Fri Apr 01, 2011 1:33 pm
Awesome, that works. Thanks
Ericular
