reindexing server from android app??
Postby ace518 » Thu Apr 07, 2011 6:29 am
before i ask for this in the feature request, or try to build a button into the app for my own copy(Love open source stuff), is there a way to force a refresh of the index from the android app. I know i can refresh the folders the android app sees, but I mean, to force the server to reindex its contents. If i add a log into my file server remotely and move folders around, add music to a folder, i'd like to be able to get to it without having to use the web interface. Unfortunately at work, I can't get to the web interface, and am stuck with just the android app. Thank you.
ace518
Postby bushman4 » Thu Apr 07, 2011 3:45 pm
I do not believe it is currently possible, as there is no "reindex" command exposed in the programming API.
See:
http://www.subsonic.org/pages/api.jsp
...for what is possible to do from a remote client.
HTH,
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Re: reindexing server from android app??
Postby GJ51 » Thu Apr 07, 2011 5:32 pm
ace518 wrote: If i add a log into my file server remotely and move folders around, add music to a folder, i'd like to be able to get to it without having to use the web interface. Unfortunately at work, I can't get to the web interface, and am stuck with just the android app. Thank you.
Why not just reindex after you make the changes you've just described?
