Question on Downloading and ports
Postby MichaelCampbell » Tue Sep 06, 2011 8:23 pm
I have my service running on a non-standard port, (say, for example: 1234), with port 1234 port-forwarded to my subsonic box through the router. Everything works great.
When a user chooses to download a file (which also works fine), does the download go through that same port 1234 or if not, how does it work?
The reason I ask is I'm setting up some QOS rules and I wondered if I could do this by port, or have to resort to some other means.
MichaelCampbell
Re: Question on Downloading and ports
Postby BKKKPewsey » Tue Sep 06, 2011 10:48 pm
As far as I know all the traffic goes through the open port.
No doubt someone will correct me if I am wrong 8)
Postby frotzed » Sun Sep 11, 2011 2:59 pm
Yes, any traffic to your Subsonic Installation is required to pass through the port you specify. Subsonic will not use a different port without telling you. Also, I'm _almost_ certain that the download option would be over http or https (if you configured it that way) rather than ftp. So all the traffic will 1) be standard http and 2) will therefore use the port you specify.
frotzed
