Bug - Last.fm password dropped
Postby tkelito » Fri Sep 16, 2011 3:52 pm
Quick bug I found, if you change anything on the personal settings page (like the theme) Subsonic "forgets" your last.fm password and will throw a failure in the log stating it couldn't scrobble the track. You then just have to re-enter your password and save it again in personal settings. I guess the fix could be to move last.fm to it's own separate tab in settings or to figure out why it is dropping. Honestly I wish it was on it's own tab because most of the users on my server don't seem to find it very quickly (if at all) in personal settings.
Big fan over here. Subsonic changed the way I listen to my music.
tkelito
Re: Bug - Last.fm password dropped
Postby BKKKPewsey » Fri Sep 16, 2011 10:33 pm
I just tested this as I dont change themes much and didnt find any problem :?
According to my log (and last fm) tracks scrobbled (stupid word) ok after changing themes and back again.
Could you give us us some more info eg what themes etc
Postby PRAEst76 » Sat Sep 24, 2011 8:35 am
I've had this same issue on Subsonic through multiple versions for years. Occasionally (maybe once a month) it will stop scrobbling and when I check the log on the 'About' tab it shows eg:
[24/09/11 09:02:03 BST]   WARN   AudioScrobblerService   Failed to scrobble song 'Ohne dich' at Last.fm. Wrong username or password.
...for every song I play. After going into the settings and re-entering my password it starts to scrobble successfully again, but it is rather irritating. It never occurred to me that it might follow a settings or theme change. I don't tend to change them very often and most of the time it is to enter this password again after another scrobbling failure.
PRAEst76
