redirecting
redirecting
Postby columbiabbs » Sun Sep 25, 2011 6:41 pm
Hey Guys:
My site is being redirected to the Subsonic.org Homepage. not to Columbia.subsonic.org site.
I get this when I check it. Columbia.subsonic.org is already in use Please use another.
Why?.
William
columbiabbs
Re: redirecting
Postby BKKKPewsey » Sun Sep 25, 2011 9:31 pm
columbiabbs wrote:Hey Guys:
Why?.
William
What site? :?
Columbia.subsonic.org is going to IP 24.88.76.61 which is your SS server isn't it?
Re: redirecting
Postby columbiabbs » Thu Oct 06, 2011 5:54 pm
it is still not working!!. this is some thing that has just started after 4.4 and 4.5 here is a copy of my SMC router setup.
Status
You can use the Status screen to see the connection status for the SMC8014WG-TWC WAN/LAN interfaces, firmware and hardware version numbers, any illegal attempts to access your network, as well as information on all DHCP client PCs currently connected to your SMC8014WG-TWC.
RG Functions: Enabled
NAT: Enabled
DHCP Server: Enabled
Firewall: Enabled
Current Time: THU OCT 06 12:20:09 2011 System Up Time: 001 days 01h:17m:34s
INTERNET
WAN IP: 24.88.71.143
WAN Subnet Mask: 255.255.248.0
WAN Gateway IP: 24.88.64.1
Primary DNS: 209.18.47.61
Secondary DNS: 209.18.47.62
GATEWAY
DHCP Gateway IP Address: 192.168.0.1
Subnet Mask: 255.255.255.0
DNS Proxy IP Address: 192.168.0.1
INFORMATION
Software Version: 4.05.34-TWC
Hardware Version: 2A
RF Cable MAC Address: 00:26:F3:36:8E:BD
USB MAC Address: 00:26:F3:36:8E:BE
Wireless MAC Address: 00:26:F3:36:8E:BF
RG WAN MAC Address: 00:26:F3:36:8E:C1
Serial Num: H21031010AF0
WIRELESS
SSID: toomer
Encryption Type: No Encryption
Encryption length: 0 Bits
Encryption Pass Phrase: No Encryption
Channel Being Used: 11
Interfaces Uptime and Traffic Count
LAN Uptime: 25h:17m:34s ,Receiving 154362014 bytes , Sending 465608961bytes
WAN Uptime: 25h:16m:54s ,Receiving 444692457 bytes , Sending 134507101bytes
Network Log
View network activity and security logs.
columbiabbs
Re: redirecting
Postby BKKKPewsey » Thu Oct 06, 2011 8:27 pm
Hmm! That was all very interesting but you still haven't told us what is not working? :?
IF your SS server is running and IF it is connected to port 4040 then it seems your port is blocked.
Have you checked with canyouseeme.org to make sure your port is open?
Re: redirecting
Postby columbiabbs » Thu Oct 06, 2011 10:54 pm
ok Sorry about that.
You cant connect to my system @ columbia.subsonic.org yet it is up and running. When I check it from Subsonic I am now getting
1.Status: Successfully forwarding port 4040.
2.Status: The web address "columbia" is already in use. Please select another.
I do not think that their are TWO <columbia.subsonic.org>
3. now if I change the address to another address i get
4.tatus: wa2gym.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
thanks for your help.
William
Now this system is running on a MAC Computer OSX 10.6
columbiabbs
Re: redirecting
Postby BKKKPewsey » Thu Oct 06, 2011 11:43 pm
I doubt there is either and your.subsonic.org address is going to your router.
Have you checked, as asked, with canyouseeme.org from the server machine?
Can you access SS from within your own LAN?
Also check that you haven't got two instances of SS running on the same server?
If you require further help I would suggest that you post in the Help section and read http://forum.subsonic.org/forum/viewtopic.php?f=2&t=5506
