I'm behind a firewall I can't configure... what do?
Postby gmad321 » Sat Oct 15, 2011 6:48 pm
Issue is, I'm now behind a firewall I can't configure. Essentially the router belongs to someone else.
I have donated to subsonic and use the myname.subsonic.com - does that allow for access behind a firewall?
If not, is there a way I can connect in without configuring the FW?
thanks!
gmad321
Re: I'm behind a firewall I can't configure... what do?
Postby martyscholes » Sat Oct 15, 2011 8:55 pm
You're pretty much sunk unless the firewall honors PnP requests, in which case it should work.
martyscholes
Postby lunix_ebooks » Mon Oct 17, 2011 7:32 pm
You can do this with reverse SSH tunneling:
http://www.alexonlinux.com/reverse-ssh- ... nat-router
lunix_ebooks
