Video Transcoding=3000Kbps on LAN, and 1000Kbps on WAN. why?
Postby fventura03 » Mon Nov 28, 2011 11:15 pm
Is there some setting that is restricting my video transcoding to be a lot slower on the internet then it is when I'm at home?
for example, my connection is 50mbps down, 20mbps up, when I'm at home, I can easily get 3000Kbps from subsonic while watching a video, but I can't get the same speeds while I'm anywhere else, neither can my friends...
Connection isn't an issue because my friends connections are at least 20mbps down, which should easily be able to catch up with subsonic transcoding.
it's not a hard drive or server issue because I've been able to send files to friends and it easily maxes out my speed (1.7Mb/s - 1.8Mb/s)
the only thing I can think of is maybe something in the coding that's not allowing full speeds. I also noticed when someone downloads a file direct from my subsonic that it won't max my bandwidth, except it goes at 1000Kbps still.
Any ideas? it's been bothering me forever. my transcoding is limited to 1000Kbps max on externalplayer.jsp - even if I set it at 2500-3000 it doesn't change anything
fventura03
Re: Video Transcoding=3000Kbps on LAN, and 1000Kbps on WAN.
Postby kleverbear » Tue Nov 29, 2011 7:08 pm
I read a post around here stating you need to set up your player settings. Might want to try that.
Ubuntu 10.04 LTS
Atom @ 1.60GHz, 4 cores 2Gb ram
6 Users
SubSonic 4.6 (build 2585)
2,575 artist
2,053 albums
16,090 songs
288.69GB (~4,484 hours)
kleverbear
