Subsonic user statistics for web and mobile usage
Postby kayvee » Mon Dec 19, 2011 9:20 pm
Does the 'Downloaded (MB)' value shown for users in the web interface include downloads from the mobile apps also? I feel that it is shows only web usage. Is there a way to include usage from the mobile apps also? Alternately, is there a log file somewhere that keeps track of the network usage for each user irrespective of how the server is accessed by the user?
kayvee
Re: Subsonic user statistics for web and mobile usage
Postby ytechie » Sun Jan 08, 2012 6:40 am
I think the download section shows all download activity including mobile app download info.
ytechie
Postby kayvee » Sun Jan 08, 2012 2:35 pm
I suspect ihat it is not the case. Are you sure?
Is there a place where the exact number of kbs downloaded is stored? I can always download an extra track using my phone to check. I cannot make out if it increased or not by looking at the graphs.
kayvee
Postby ytechie » Sun Jan 08, 2012 3:02 pm
To tell you the truth, I don't use the graphs at all. Instead, if I want to check usage data, I go to [subsonic]/db.view and type "select * from user"
That may be what you are looking for. :wink:
ytechie
