JWPlayer cuts off last second of music
Postby ZombyWoof » Wed Dec 21, 2011 1:22 am
Hi. New user struggling with an installation on Ubuntu Server 10.04. My desktop is Ubuntu 10.04 w/ Gnome.
For the most part Subsonic is trouble free. But I noticed the other day that it cuts off the last second or so af a file. My music is stored on the server as flacs. I play on another PC using webplayer, jwplayer. I have seen no errors in the logs, It does this with all files, you just can't tell with some music because of fades. It does not do this if I use an external player. I use Subsonic v 4.6 build 2585 and have upgraded the jwplayer to the latest, 5.8.2011. Nothing seems to help. My server has 1.5 gig of ram and usually hass > 1 gig free.
Does anyone have any experience with this problem or troubleshooting tips?
ZombyWoof
Re: JWPlayer cuts off last second of music
Postby germain35 » Wed Dec 21, 2011 4:12 pm
Hi mister Zomby !
I've got the same problem with subsonic-4.6 (WAR version deployed with tomcat6) on Ubuntu 10.04 with all players like iSub (app fo iPhone) or JWplayer. All my songs stop a couple of seconds before the end. You are the first having this issue since i posted here : viewtopic.php?f=4&t=8443
The only solution for me is to rollback to V4.5 and all work fine, there is no answer to this problem...
germain35
Postby ZombyWoof » Fri Dec 23, 2011 3:39 pm
Thanks for the info.
Rather than backtrack I'll give the developer a chance to fix this.
NOTE to Sindre: I will donate once this works.
ZombyWoof
Postby BKKKPewsey » Fri Dec 23, 2011 5:03 pm
This does appear to a OS related problem but to give the devs a chance can you confirm if it is only flacs that are a problem or do other audio files, specifically mp3s, cut off early.
It does seem to be connected with
4.6beta2 change log wrote:Bugfix: Don't estimate content-length for web players.
I wonder if that regression did not get updated in the 4.6 Final for your version :?
Postby ZombyWoof » Sat Dec 24, 2011 11:33 pm
Does it with Mp3s as well.
ZombyWoof
Postby eblade » Sun Dec 25, 2011 1:53 pm
It cuts off video as well, afaict.
The REST api only gives us time in whole seconds, which is generically Bad - - if we have to depend on knowing the duration of the media to be able to end it and move on to the next thing, then we're only getting a round number, that is not accurate.
eblade
Postby ZombyWoof » Mon Dec 26, 2011 9:58 pm
eblade wrote:It cuts off video as well, afaict.
Seems like you might be on to something. I inserted a few millaseconds to the front of a few flac files to make them whole seconds.
Now they work fine.
Is this fixable?
ZombyWoof
Postby eblade » Tue Dec 27, 2011 1:09 am
It sounds like JWPlayer is probably doing the same thing that I do on my webOS player, since I don't get a function call telling me specifically when the thing is done playing, I check it's status regularly, and if it's within one-second of completion, i move on. I'm planning on making it start a 1-second timer before moving on, and having that trigger the moment it gets to the 1-second-left mark, but that's a really hacky workaround, if i could just get a more accurate duration, that'd make me happier.
eblade
Postby ZombyWoof » Sat Jan 14, 2012 2:33 am
No more comments?
I guess I need to find an alternative webplayer.
ZombyWoof
