How Do I Delete Servers on Android
Postby distronic » Tue Jan 10, 2012 8:31 pm
I would like to delete servers in my list when I go to Select Server. If someone could please help, I would greatly appreciate it.
Thanks.
distronic
Re: How Do I Delete Servers on Android
Postby text » Wed Mar 07, 2012 11:29 pm
You can not do this. You can either change it to a new address or leave it as it is. The only other way is to uninstall and reinstall subsonic on the android. I had the same problem.
text
Postby baxtr » Fri Mar 09, 2012 9:09 pm
just overwrite it with a blank one, you do need to specify a url in correct form so just use something like "http://add.new.url.com" or something, that will wipe the old url out and place that on in which you obviously won't be able to connect to.
baxtr
