Left column won't load list of artists [Resolved]
Postby houdini2930 » Wed Jan 11, 2012 7:49 pm
I'm using a Windows 7 installation of Subsonic and it's worked fine for a year or so. I recently moved the location of my music library. Since then, I can still search and stream the library just fine, but the left column won't display the list of artists that should be there. I've tried accessing the left frame directly and clearing all cookies and caches. I've tried using different computers and browsers but still no luck. I updated my library 24 hours ago... is this something where it needs several days to build the list? Or perhaps it's just a bug and not working?
houdini2930
Re: Left column won't load list of artists
Postby ytechie » Wed Jan 11, 2012 8:11 pm
I assume you changed the settings to reflect the new music location. Did you restart the server? Sometimes that helps.
ytechie
Postby houdini2930 » Thu Jan 12, 2012 2:52 pm
That did the trick. Thanks.
houdini2930
