Backup and restore of settings? [Resolved]
Postby TweakEn » Sun Jan 22, 2012 8:14 pm
How do I backup/restore settings. I have windows installed on another drive and I just want to know what it is I have to transfer to my new Windows 7 disk that will include all of the settings that I made on my previous Windows 7 disk, i. e. User accounts, music folders, etc... I tried just copying over the contents of the Subsonic folder, but this does nothing. WHERE ARE ALL OF THE SETTINGS HIDDEN??!? Thanx
TweakEn
Re: Backup and restore of settings?
Postby ytechie » Sun Jan 22, 2012 8:32 pm
You have to shut the service before transferring anything. Most of what you're referring to is in the db folder.
ytechie
Postby TweakEn » Mon Jan 23, 2012 12:36 am
Yup, I did that. Went into task manager ended process subsonic, copied all the files, restarted.... When you said db, I was like, there's no db folder in the subsonic folder of my program files, but I just realized that there is a Subsonic folder in the root of my hard drives directory. So, thank you for pointing that out, I transferred it and it worked with just shutting down the server. Now I don't have to redo all my accounts AGAIN.
TweakEn
Re: Backup and restore of settings? [Resolved]
Postby burner247 » Mon Jul 02, 2012 8:00 pm
Which file in the db folder has the user accounts? Reinstalled Subsonic and that's all I want from my last install.
burner247
Postby BKKKPewsey » Tue Jul 03, 2012 12:26 am
subsonic.script
