Tag Issue
Tag Issue
Postby pra98cam » Sun Sep 23, 2007 1:03 pm
Hi Sindre,
Just noticed an issue in the new beta (it may have been there before but I can't remember). Tracks that have a "<" symbol in the title aren't displaying correctly. The < and everything after is blanked out in the title display.
For example I have a track called "Less Than Zero (<0)" which desplays as "Less Than Zero (" and another called "My<Dsmbr" which displays as "My". The hoverover displays correctly but not the actual title display itself.
Thanks again for a top update :)
Carl.
pra98cam
Postby sindre_mehus » Mon Sep 24, 2007 2:15 pm
Hi Carl,
You're right. I'll fix that in the next version.
Thanks for reporting it!
