Subsonic directory size over time
Postby motherfo » Fri Feb 24, 2012 8:40 pm
Hi there, I've searched and found this guide: viewtopic.php?f=2&t=9024&hilit=move+folder
I may do this, but I wanted to ask, how big does the subsonic directory usually get over time? Mines around 55mb as is.
I do have an SSD in my WHS 2011, so if it stays under a gig I will be fine, but I'm curious what will make it grow.
Many thanks,
-Fo
motherfo
Re: Subsonic directory size over time
Postby BKKKPewsey » Fri Feb 24, 2012 10:38 pm
motherfo wrote:but I'm curious what will make it grow.
Generally the size of your media library.
I just checked my SS dir and at present it stands at 230Mb.
I think most of that is the thumbnails for the cover art - that is with a library of just under 80k tracks.
Postby motherfo » Mon Mar 05, 2012 3:04 am
If that's as big as it's gotten and it's mainly pictures, then I'm not too worried.
I was going to be concerned if it was gigs.
Thank you for the response. :)
-Fo
motherfo
