minimum system requirements
Postby Fodox » Fri Apr 27, 2012 3:16 pm
Hello.
Before I install Subsonic, what are the minimum system requirements?
I have a PC always-on connected to Internet, P3 1Ghz + 512Mb ram + ubuntu 10.04 Server + some thousand of mp3. Can it work?
Thank you
Fodox
Re: minimum system requirements
Postby bushman4 » Fri Apr 27, 2012 3:23 pm
Sure it will. You may be limited to the amount of transcoding that you can do, but if you really have just a ton of MP3's you won't need that much anyway.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
