Cannot play album - iPhone
Postby Eddiie » Fri Apr 27, 2012 11:24 pm
Hi, I have donated a few months back.
I have some albums that will only play 1 song on the iPhone client. Think I have seen it work ok with other Albums when using the "Play Album" button.
It is a real pain as I swerve all over the road trying to get to the next song. The app re-connects to the server and re-downloads the list of songs even though they are still on the screen from last time. It takes forever.
Also, DDNS service or whatever that lets you make up a domain name, example - Eddiie.subsonic.org does not work (this is not what I setup - it is just an example). I was under the impression this would work after donating.
Constant cutouts, can there be a buffer of some sort on the player (or make it larger) ?
I check for updates but there never are any.
Did I donate to a dead project?
Eddiie
Re: Cannot play album - iPhone
Postby Eddiie » Fri Apr 27, 2012 11:29 pm
Think I found the answer about the Vanity DNS name thing.. It is an HTTP redirect, not real DNS.
Eddiie
Postby BKKKPewsey » Sat Apr 28, 2012 2:10 pm
I would suggest that any problems with regarding the iPhone app should be directed to the developers of the app.
With regard to the custom name - have you entered the licence details into SS?
If you hit the donate button SS will tell you if it is licenced.
