ffmpeg 10.2
ffmpeg 10.2
Postby Robandcathy » Sat May 05, 2012 7:36 pm
Recently had added a few more users, and seemed like trans coding is suffering while I think my processor is fast enough, so I did some digging and since I know ffmpeg does trans coding on the fly I decided to check my version since I had to reinstall subsonic and it from 2011 which if I remember correctly ffmpeg was at a stand still for a long time, but checking there website seems they have been very busy in 2012 latest build is 10.2, so after searching the internet for a exe file as thats what subsonic uses I hit a wall. Does anyone know where I could get the exe file or how to setup the file format they have within subsonic?
Thanks in advance. :mrgreen:
Pain is a state of mind
Weak minded people feel pain
Robandcathy
Re: ffmpeg 10.2
Postby hakko » Sat May 05, 2012 8:37 pm
According to http://ffmpeg.org/download.html, you can download windows binaries from http://ffmpeg.zeranoe.com/builds/
MusicCabinet developer
hakko
Re: ffmpeg 10.2
Postby Robandcathy » Sat May 05, 2012 11:28 pm
thats great lol but how do I get subsonic and binary files to work together, as I said right now its in a old exe format, that subsonic calls on when needed. I use windows home server 2011 (aka known as SBS 2008) I would be happy to use binaries if I knew how to implement them.
Robandcathy
Re: ffmpeg 10.2
Postby BKKKPewsey » Sun May 06, 2012 12:14 am
You just download a static build which is one exe file.
