Couldn't play FLACs, but now Tomcat wont start!
Postby ghostcorps » Sun Jun 03, 2012 2:57 am
Hi Guys,
I am using FreeBSD 8.2.
I have been using the standalone version for a while now and while it did occasionally crash it was working fine, but then I downloaded a number of FLAC albums and they would not play.
So I decided to install the full version and see if that would work. So using the FreeBSB port system I installed Tomcat6 and Subsonic which worked immediately, it played FLACs and was much faster. BUT due to being in a /subsonic subdomain the redirect that I received after donating was broken.
I tried for hours to fix this with no success, I then decided to just rename /subsonic to /ROOT (after moving the original ROOT of course) but this did not work. Then after moving it all back, I was unable to get to anything except the index.html in ROOT, I could not get to the manager or subsonic, both attempts giving me the alert that the page was not accessible.
After an hour or so of googling I decided to just uninstall subsonic and Tomcat6 and try again. I uninstalled them, deleted the home folder and re installed.
Now Tomcat won't even start!! And to make things worse, it isn't writing any logs.
This is killing me, I can use the standalone app but it is unstable and means I can not listen to FLACs, what could I possibly have done wrong? Surely after deleting /usr/local/apache-tomcat-6.0 and reinstalling it should all be back to scratch.
Thanks for your time
ghostcorps
Re: Couldn't play FLACs, but now Tomcat wont start!
Postby ghostcorps » Sun Jun 03, 2012 4:26 am
I just tried to watch a movie on the old unmodified standalone installation and am getting 'video not found or acces denied' ! ? :(
Why did it all implode on me?! I didn't change anything :(
ghostcorps
Postby ghostcorps » Sun Jun 03, 2012 5:16 am
I have Tomcat started again, but am still getting this:
HTTP Status 404 - /manager/
type Status report
message /manager/
description The requested resource (/manager/) is not available.
Apache Tomcat/6.0.35
ghostcorps
