What I want to know is what features people are looking for in the Android app? What would make your experience better? And if its one of the features I already listed which are most important to you?
jol wrote:Hi,
this is the list of (mostly quirks) I had for the original Subsonic Android app:
Android Quirk: jukebox stops playing when unplugging headset - do you support Jukebox? I love it..
Android wired headset buttons - double press support - would by new headset as the buttons are dead in the meantime..
Randomness in Play Shuffle of Android App
Search in offline mode on Android.
and for search in general I don´t know whether the client can control AND vs OR of search terms, but I´d prefer and.
Best regards, jol
Other players skip to next title.daneren2005 wrote:2) What is it supposed to do on double press and by that do you mean press twice in a row quickly?
Should have made explicit that I am using offline a lot (outdoor), and then randomness is not the server, and delete from cache limits the choice to the titles I like.daneren2005 wrote:3) I can't really fix the "true" randomness of it since the request is fulfilled by the server, but the changing the size of the random playlist shouldn't be that hard (probably would do a option for different sizes). I'm not sure why you would want a delete button though since having it in the cache doesn't really make a difference for the most part.
daneren2005 wrote:What I want to know is what features people are looking for in the Android app? What would make your experience better? And if its one of the features I already listed which are most important to you?
jol wrote:Other players skip to next title.daneren2005 wrote:2) What is it supposed to do on double press and by that do you mean press twice in a row quickly?Should have made explicit that I am using offline a lot (outdoor), and then randomness is not the server, and delete from cache limits the choice to the titles I like.daneren2005 wrote:3) I can't really fix the "true" randomness of it since the request is fulfilled by the server, but the changing the size of the random playlist shouldn't be that hard (probably would do a option for different sizes). I'm not sure why you would want a delete button though since having it in the cache doesn't really make a difference for the most part.
Just wanted to give it a try, but Google Play lists it at 2$ - strange for a fork of a GPL project, isn´t it? Cost of distribution?
Best regards, jol
mr_nobody wrote:daneren2005 wrote:What I want to know is what features people are looking for in the Android app? What would make your experience better? And if its one of the features I already listed which are most important to you?
If you can fix the issue mentioned in this thread, some of us would be very happy:
viewtopic.php?f=5&t=9716
dunnno wrote:Looks like, in my end, your app is faster than the original one.
Am I blind or I don't find the offline option, where is it ?
Also, I have something like a bug ( ?) that I had on the original app too. It plays the first song of my current Playlist twice.
EDIT : There aren't the play/pause, next, previous buttons anymore from the drop down status bar? Annoying since you have to open the app now
daneren2005 wrote:I'll look into it, but since I haven't had that issue myself it will be hard to diagnose. Mostly I can just try increasing the buffering and see if that helps.
dunnno wrote:Here is a screenshot for the buttons. Is the offline the cache option?
EDIT : oh, my bad, I found the offline thingy. But how does it work? When chosen, everything disappear. How do you choose songs to be "offlined"?
albercliff wrote:daneren2005 wrote:I'll look into it, but since I haven't had that issue myself it will be hard to diagnose. Mostly I can just try increasing the buffering and see if that helps.
I've tried to do that but with no luck.
daneren2005 wrote:I just tried downloading the official app and they don't show up for me still. In fact I didn't even know that you could have buttons inside of the notification. In fact I just did some quick googling and everything I saw says that you can't do that. I'll look into it more tomorrow though I'm probably missing something in how I'm searching. Right now the offline works just the same that it does in the current app. It is just an offline view for the music that you currently have downloaded. As I have been preparing to leave for vacation that has probably been my main annoyance is the lack of a way to set music to download (using pinning is kind of non-intuitive) so I will be adding it in the next few days.
